I've now had enough time to play with the new pump's built-in schedules, and am trying to figure some things out.
My Weir doors have never flapped unless the wind is very strong and blows hard on the water surface. Otherwise when the pump is running they just open, and stay open. They don't open all the way but they certainly don't open and close. If I drop the speed too low, even though they open a bit, debris on the surface just floats on by. The doors are new, and are working properly. For example at 1100 rpms, it's hard to tell if the water is actually moving. I can feel water being returned into the pool when I put my hand in front of a jet, but, for sure, no debris is being pulled into the skimmers as it floats by. At 1700-ish some debris is pulled in as it floats by. At 2350 RPM, most of the debris going by gets pulled in. A I doing something wrong?
Also, how do you guys know how much electricity is being drawn by your motors at different rpms?
