My pool pump was a cheap Home Depot pump that came with the house when we bought it last year. It finally gave up the ghost two days ago. So we at a minimum need that as soon as possible. Pinch a Penny is running a 15% discount locally this week on Pool Pumps, Salt Systems, and Automation. Also FYI - I have a full roof of solar panels that I use for my home, plus a pool heater that I never use.
Here are a few other things I would like to do at the same time if it makes sense.
I want to switch from chlorine to salt system. I also think I want automation on both the pump and the salt system, so I can control it from my cell when travelling.
They've given me a quotes on the following:
New Pump + ($200 install) + PVC 3 way valve 2" no lube $96.99 + PVC 2 way valve no lube 2" $159.98 + installation of valves ($125.00)
Let me know your thoughts because I'm about to blow $10k on this project!
Thanks!
- Superflo VST Pump 115/230V - $1,147.50
- Intelliflo 3 VSF Pump - $1980
- Pentair Intellicenter Sys I5PS w. IC40 - $4,376.65 + $1100 (install)
- Swimclear 200sqft Cart Filter - $950.00 + $200 install
Thanks!
