- Nov 28, 2020
- 51
- Fiberglass
- Astral Viron eQuilibrium EQ25
Hi all,
I have an Evo-heat heat pump located in Australia. I have had it just on three years and now the unit has totally failed. It's a expensive 27kW 3 phase unit. The techs said the unit failed because;
1 - the coupling to the water pipes was not properly installed so pool water ended up leaking into the inside of the unit and onto the heat exchanger and other bits,
2 - They said the unit had not been set up properly by the installer and a drain plug in the bottom had not been removed. This meant that with the regular water entering, the unit could not drain fast enough and the parts were sitting in chlorinated water.
The installer is saying that I am to blame for this as I have not had annual services on the heat pump. I didn't recall any material highlighting that annual servicing was required.
I am interested to know whether it's just me, or does everyone else out there have there heat pump serviced annually even if it all seems to be working fine?
