This is my third year owning the pool and renovated it this spring. The pool is 23,000 gallons, diamondbrite French grey plaster, tile and ep Henry bull nose coping. I have a solid Anchor safety cover. I’m preparing to close the pool and have several concerns that I never worried about in years past because I knew it needed renovating and the plaster was already damaged. Now that everything is fresh I’ve been maintaining it as close to perfect as possible. Want to take good care of it over the winter also.
First, water level. I’ve traditionally lowered to just below skimmer mouth which basically means stopping when the tile is fully exposed. I have a tanning ledge that’s 12” deep when pool is filled but have a step on it almost even with the tile line and a step on the far end of the pool coming off a bench that’s exactly even with the tile line. It will be slightly exposed if I drain to bottom of tile line. Should i be concerned with water level impacting freeze thaw on those steps? The tanning ledge was deeply pitted when we bought the house. I have no idea how they maintained the pool, but know it wasn’t great. Lots of staining and pitting in the finish after 13 years before we redid everything this year. What’s the ideal height for me to lower water? Trusted pool guy says just below the skimmer. Will i develop a water ring in new plaster with some if it exposed?
Chemically I’ve been balancing everything using TFP pool test kit for two years. This year I’ve tried to maintain levels that satisfy both pool builder guidelines (National Plasterer’s Council Guidelines) and TFP. NPC uses LSI. I’m concerned about keeping my water balanced with LSI once temps drop.
I’ve purchased a submersible pump with a 2” outlet that i can attach my backwash hose to. If i use this to circulate water and keep chemicals balanced all winter, how long do I have to run it to circulate 23,000 gallons sufficiently?
Current levels:
FC: .5
CC: 0
pH: 7.8
TA: 80
CH: 250
CYA: 60
Temp: 75
TDS: 945
Planning to adjust my pH down with some acid and if I close on Tuesday as scheduled Pool guy will add liquid chlorine. Should I be concerned with these levels? Attached the NPC guidelines also.
Finally, if someone wants to tell me to just stop being a lunatic and that my pool will open just as I closed it without crazy interventions during the winter, I’m more than happy to hear that also. It was a huge investment that I don’t want to screw up.
Thank you!!
Current levels:
FC: .5
CC: 0
pH: 7.8
TA: 80
CH: 250
CYA: 60
Temp: 75
TDS: 945
Thank you!!
