Do any of you know of any connectors (or where I can look) to connect a Polaris360 to my 37 year old Anthony Pool? The jets are NOT threaded and are smaller than the connection for the Polaris360.
If you have 1.5" return plumbing, you can use this kit. In order to get a 360 to work using a return line, other returns will have to be blocked off. This kit will allow for that. If you can return the 360, I would. You will not like what happens to your pool if you start blocking return lines. A robot or suction cleaner in the skimmer with something like a VacMate are better options.
Polaris 1-1/2" Stub Pipe Connection Kit 9-100-8003, Buy the 1.5in Stub Pipe Connection Kit is an accessory for your Polaris cleaner. In-stock and ready to ship.
