Polaris Pressure Stick, Polaris 360 #9-100-6000
Midgetguru
1
Tangello53!
I purchased this pressure stick from Amazon. Unfortunately, the seller did not provide any instructions etc. with the purchase. I am currently troubleshooting my Polaris 380 - and have reached this stage. However l, I want to avoid making stupid mistakes/errors in setup and found this forum which looks like it has what I am looking for: educated sound advise. Now, correct me if I am writing here - but should there not be some type of nipple here er adapter to accommodate my pressure-side hose? Things like that, Thank you all in advance. Question: how do I properly use this?
Welcome to TFP.
Never saw that before.
You have a link to it?
What are the problems with your Polaris 380?
This one is for the Polaris 360 which has a larger diameter hose.
You need the one for the Polaris 180/280/380, Polaris part number G35.
(You'll also need a pressure gauge).
Remove hose from inlet side of back-up valve and install in its place.
With booster pump running and holding end of wand under water you want to see 28-32 psi to verify enough pressure is getting through the hose.
