Please help. Temp too high?
The temperature sensor is probably bad.
The amps are over 8.0, which might mean that the salinity is very high.
How old is the cell.
Reverse polarity and see what the readings are.
So the cell was super calcified, but I chipped as much off as I could. Honestly there is still some on there but it’s much better looking. I don’t think the reset method mentioned is for my unit. I don’t have a toggle, it’s all just buttons
You may have nicked the temperature sensor when you were chipping.
Cleaning with diluted muriatic acid is recommended when a cell is calcified.
The plates look like the shorter plates, which means they might be for a T-9 cell.
How old is the cell?
What is the model number of the cell?
Can you count the plates and measure the length of the plates?
Here are the dimensions of the Hayward plates:
T-15 has 13 Titanium Plates, 150 x 63mm. Produces 1.47 lbs/day.
T-9 has 13 Titanium Plates, 101 x 63mm. Produces 0.98 lbs/day.
T-5 has 7 Titanium plate, 150 x 63mm. Produces 0.735 lbs/day.
T-3 has 7 Titanium Plates, 101 x 63mm. Produces 0.53 lbs/day.
What is the actual salinity?
You need at least two very reliable salinity tests including a K-1766 and an electronic meter.
What is the cell type set in the menu?
I have none of the testers. This was an abandoned house we bought and don’t know anything about any of the pool stuff. The menu option isn’t there on mine to reverse polarity. It only seems to show up for the 1 second the thing tries to turn on.
I have no clue. There is no model number and I don’t know what plates to measure or how. I literally only know that water goes in a pool and at some point the water goes through all the mechanical stuff. I have the knowledge of a five year old lol
