my husband ordered one and it has been shipped so it is possible it will arrive sooner. he has had surgery and is pretty drugged up to remember the exact name, nor can i find the info at this time. he did say it was one that was recommended from this wedsite. i am confused as to why i would let my chlorine go down, if i bleach it like you suggested, wont that raise the chlorine levels? and knowing that my cya was high before we started and with the strip test at the pool place, can i assume that the chlorine will not be used up as fast? should i just let everything go until i get the kit? but continue to monitor the ph? It is not too hot here, so i would think that the chlorine will be locked with the cya being high. although i guess none of my readings are correct though. if i still have algae now is it still ok to add the bleach? thanks again. just trying to figure out if i should continue to add bleach if i still have algae and my chlorine is still high. if i find out more about the kit i will post back.
