Hi, has anyone wired a pentair intellilevel automatic pool filler up before? I believe the prior pool builder cut the cord coming off the intellilevel to the control panel (easytouch 8 in my case). From the intellilevel manual it looks like it is suppose to be a three wire cord with a connector that goes into an actuator valve spot on the control panel. The issue is the cord coming from the intellilevel to the control panel is 5 wire (black, red, white, yellow, green). See attached pictures. Anyone have any idea on this? I called pentair and they said it's suppose to be 3 wire (not 5). Should I just hook the black, red, white to a 3 pin connector (see link below) and connect to a valve spot on the easytouch 8? Then wire nut the yellow/green? Thanks for your help
