To get a P4 to be able to control more than one speed on an IntelliFlo pump you need an IntelliComm II board. Each relay you use on the P4 gets you one speed, so two relays gets you two speeds, three get you three speeds. Four speeds is the max with the IntelliComm II, but they can be any four speeds. A typical setup only needs one or two different speeds, occasionally three.
