Hi all, I'm trying to get my Raypak heater connected to my intellicenter but am having some problems. It seems as though both the gas and electric terminals on the intellicenter's circuit board are in a always on configuration. I'm wondering if there's some setting someplace in the software to disable that as I find it hard to believe that both circuits are screwed up, especially being two different heater circuits.
What I've noticed is if I put a meter on both the gas terminals as well as the electric heater pins I'm getting connectivity (single to turn the heater on) even if nothing is turned on. Visually I can also see the LED light Infront of the electric heater pins as always being on, with our without any heaters configured and with or without the pool being on. What's also odd is I have no continutity between the two solar heater pins so that relay should be open but when I connect the heater's control wires to that port it turns on. I snipped the connections to test and it's for sure open so I'm not sure what's going on. If the cable is disconnected from the intellicenter the heater is in the off setting, but once connected, even to a port that has no connectivity it turns on.
Pentair thinks it's a bad board, but at 600-1300 replacement (1 year warranty... on a 2 year system... joy) I'm really hoping its not the case. The only other heater relay that's on the board and doesn't have it's LED lit is the solar connector.
Any thoughts on what could be the problem?
