Hello Hello... Wanted to open this thread again. To consolidate a couple of posts to here: Found a guy in NJ that repairs electronic stuff, Pulled the board, got it back and installed it, hit the juice, no sparks or bad stuff happened. However... the software would only loop. Ok, got in Service mode, tried to reinstall my last backup. No go. Finally gave up and did a factory reset. Of what? Good question. As now the system is in contact with Mother (Hayward Server) and I make it to System Info and::: MSP version R.4.8.1, MP R.4.5.0, RB (?) R1.0.4, IO Expander R.1.0.4 Hmmm. That's how I set things prior to shipping for repair. Except...
I one thing that did get reset to factory was the Configuration. No, it won't allow a Restore of my backup. I'm now in the middle of Reconfiguration. Locally known as, figure out how the 1st electrician set all the relays and valves with the above picture (Rats Nest) just for fun. All of my Valve wire have a color tape at the valve end and nothing at the Box. So, to my point/question. Does anyone have a source for these? I'm going to trim the valve wires (15' is a bit much) and use new connectors to save some time.
All in all... this is fun. Glad to see the board runs. If I get it all back together, I'm going to hire out as an Installation Guru. Not that hard to do, just pain having to go over sloppy work.
Cheers, Carl
