Sorry for the lengthy post…
So we had some trouble getting our pool clear last year but after some struggle we got to a level that was swimmable, but not as clear as I would have liked. We ended up having our pump completely serviced changing out seal, o-rings, cleaning impeller, etc. Seemed to be running better at close but never totally cleared and it was late in the season and we had to close it up cloudy. Fast forward to 2023. We opened our pool later than usual in June. We had issues almost right off the bat. One of the pipes were leaking and ended up completely letting go one night. (The pipe that goes from the pump to the filter). The pump ran dry for several hours. We reconnected the pipe and started it back up, it seemed to be running okay. I was able to get my pool to turn blue but after several weeks of constant slamming, it would not clear. Then we started having issues with low pressure. We started getting a lot of air in the pump basket. Assuming we burned out our pump because it ran dry, we had the pump serviced again, all new parts again, cleaned the impeller, etc. Reconnected everything and started it up yesterday. At this point my pool is green and filthy as it sat stagnant while we waited for the pump to be repaired. There has been some improvement but there is still air in the pump basket. Even more so if I turn off the bottom drain and just pull from the skimmer. I shocked it with 6lb of cal-hypo last night (it’s all I had). The pool is still terribly green. I plan to purchase liquid shock this afternoon and continue the slamming process. I’m worried that there’s issues with the pipes underground since there’s still air in the system and we’ve ruled out the pump. Or maybe it’s the filter? There was one time that we started backwashing without opening the outtake valve (maybe 15-30 seconds max before we realized our mistake) maybe we cracked something in the filter? I’m so beyond frustrated with this old pool. I used to have it sparkling all summer but we haven’t been able to enjoy it for around 2-3 years. It’s been nothing but problem after problem. I’m seriously considering draining the whole thing and having it redone, new everything.
