Maybe. This system uses a low-flow circulation pump that most generic aftermarket packs cannot use, as this pump will not keep up with the heater. So your new pack must be able to use this pump or you will have to replumb to the main 2-speed pump. Some minor clear hose plumbing will have to be done in any case unless an exact match can be found still in production.
Do you have a new system in mind?
