Yup for sure. Looks like it even might be damaged now if you look close. I will go have another look. I wonder why I would suddenly have a bearing issue after I replace the capacitors. Again, after I replace both capacitors in before I install the covers (and got pop and sparks) it sounded perfect
Ok. Just bought a Hayward 950 variable speed. I need to get it hooked up quickly. Keep in mind that my Prologic was previously set up to run a 2 speed pump. Until I have more time to get it set up and programmed into my automation, I would like to just give it constant power and control it manually from the control panel on the pump itself. I think I can do this by just having my pro logic think it’s on high-speed 24/7.
Below is a picture of the wires that were going to into my old 2 speed pump. I measured voltage across the wires in both high and low speed, and did not see any difference. Between white and blue is 240 V. Between white and black or black and blue it is 72 V. Again, no matter if in high or low speed. With filter set to off, it’s 0.5V across any two of the three wires.
So, can I just hook up say the white and blue wires into the new pump, tell my Prologic to run on high speed 24 seven and then control the operation of the pump on the pump control panel?
Also, kind of curious why both High and speeds show same voltage readings. How did the old pump know what speed to go in?
I also measured White to ground and blue to ground. Both are 124 V in both high and low speed. Black to ground is 2.1 V in both high and low speed. Pictures inside the box below. Based on this, just until my electrician buddy gets back from vacation, can I just hook up blue and white, tell my Prologic to run 24 seven, and control it from the pump panel?
I get 240V between white and blue regardless of pump speed. So I am thinking that if I use those wires to supply 240V, the pump will not know anything about the black wire that it's not connected to.
