I have a Hayward CL200 chlorinator. It sound like there are air bubbles inside. There are no external leaks. It is fine with me, but it bothers the wife. Any suggestions ??
Do you run your pump 24/7? If not, the best thing to do would be to remove the chlorinator, or at the very least not put tablets in it. They can cause a lot of damage to a residential pool, besides adding a large amount of CYA to the water. They were designed for commercial applications, but, at least in many jurisdictions in my state, are no longer legal just because of that CYA rise.I have a Hayward CL200 chlorinator. It sound like there are air bubbles inside. There are no external leaks. It is fine with me, but it bothers the wife. Any suggestions ??
You've been very fortunate using a tab feeder that long, especially if it is the only source of chlorine in a vinyl pool.1poolman1, I only run the filter about 6 hours a day. I see there is a lot of disfavor on this site, about chlorinators but I have been using one for about 18 years. I have gotten high CYA readings from the one place I get the water tested, but never really paid much attention to it. I guess after I use up the rest of the chlorine tablets I should just use liquid chlorine in the future as most recommend here. Thanks. Mike
Bad idea.It looks like I can turn the chlorinator down to zero which just about shuts off any water from going through the tablets.
I would seriously consider a salt water chlorine generator. Very simple device that makes pool care even easier.Soo, I guess I need to look for a large floating chlorinator and only use the in line chlorinator when needed.
