Leaking chlorinator
Jason.H.
20
North Carolina
Hello, been doing some work on our older pool and have been fixing one leak after another. There is now a leak from the under side of a Hayward cl200 chlorinator. It only gets used when go out of town. I’m not great at plumbing and it looks like all the fittings are glued and not sure how to replace the chlorinator without redoing more plumbing as there isn’t much room to cut out and add couplers or unions. What would you all do?IMG_3957.jpegIMG_3958.jpegIMG_3959.jpeg
Hello, been doing some work on our older pool and have been fixing one leak after another. There is now a leak from the under side of a Hayward cl200 chlorinator. It only gets used when go out of town. I’m not great at plumbing and it looks like all the fittings are glued and not sure how to replace the chlorinator without redoing more plumbing as there isn’t much room to cut out and add couplers or unions. What would you all do?View attachment 498625View attachment 498626View attachment 498627
A floater is a good idea but you would have to cut the chlorinator out and replumb the area. Using a union would make it an option to make it easier
Reactions: 1poolman1
