Time to start-up. The display is working and getting temperature and salt level readings.
The problem is no power out to the pump. When I plug the pump into power (without the control panel involved it works). But when I plug it into the outlet on my Hayward Aquatrol, the pump doesn't come on.
Question: I need step by step diagnostic instructions to identify which part is failing to allow the power out of unit.
OR could I just use dual plugs and bypass using the Hayward Aquatrol to supply power to the pump? Would it still generate free chlorine?
