M manders0n New member May 21, 2023 2 Jacksonville, FL May 21, 2023 Add bookmark #1 Hi! I’m in Jacksonville, FL. I recently took over pool maintenance from my husband, and am so glad to have found this group.
mknauss Mod Squad TFP Expert Bronze Supporter May 3, 2014 58,434 Laughlin, NV Pool Size 6000 Surface Fiberglass Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 May 21, 2023 Add bookmark #2 Welcome to the forum! I suggest you read through Pool Care Basics - Trouble Free Pool and even look at a few of our videos TFP-TV - Trouble Free Pool
Texas Splash Mod Squad TFP Expert LifeTime Supporter Jun 22, 2014 47,840 Texas, San Antonio/Marion, South-Central Area Pool Size 17888 Surface Fiberglass Chlorine Salt Water Generator SWG Type CircuPool RJ-45 Plus May 21, 2023 Add bookmark #3 manders0n said: I recently took over pool maintenance from my husband Click to expand... "You're fired!" Ha. Welcome to TFP!
M manders0n New member May 21, 2023 2 Jacksonville, FL May 21, 2023 Add bookmark #4 I’ve read over everything… some things multiple times. I have the k2006c test kit. I need to drain some water d/t high CYA; but I’m not sure how much? My pool is only about 2700 gallons. CYA is between 90-100
mknauss Mod Squad TFP Expert Bronze Supporter May 3, 2014 58,434 Laughlin, NV Pool Size 6000 Surface Fiberglass Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 May 21, 2023 Add bookmark #5 Drain half of the pool volume and you will lower your CYA by half.
