Hey, Y'all! First of all, thank you all for the awesome community that you have created. It has already become apparent to me in my reading that you are all trying to be super helpful.
I am in coastal NC and have recently purchased a home with an inground gunite pool that was built around 1980 and has not been in use since 2018. It is green, full of leaves and broken down debris, frogs, a turtle (family?), and who knows what else. The pool is 20' x 40' and holding water. It is 4' on the shallow end and 8' ON THE EDGE of the deep end, but goes to either 10' or 12' in the center. As best I can calculate, that puts it somewhere around 47K gallons. To add to the fun, undesirables in the neighborhood have stolen wiring to the house and the pool house and equipment, so I will be starting this process with "portable" power and pumping/filtering solutions.
I do have some pool equipment that may or may not be functional, as well additional functional equipment from a different pool (pump, sand filter, DE filter).
I have significant concerns about pumping the pool out to clean it, as our water table can be pretty high and I'm concerned that the hydrostatic pressure may result in a failure if I empty the pool. A few conversations with pool professionals have confirmed that nobody really knows whether or not I should empty it.
I have purchased a 2" trash pump with intentions of attaching a hose and pvc wand to suck out large crud that I have not been able to rake out. My thoughts are to rig a series of "filtering screens" that start large and get progressively smaller, allowing the water to re-enter the pool after passing through the screens. I am open to shocking it or using chemicals to help "lift" debris to the surface for removal. I found a few articles here and in other places regarding ProTeam's Pool Rescue, but the company tells me that they are no longer manufacturing that product due to low demand. I did research the active ingredients and am open to playing chemist to recreate the process that Pool Rescue would have provided.
Lastly, thank you in advance for any helpful hints that you all might have for me. This is a new journey for me, as I have never had a pool or spa. I am an avid DIY-er, RE investor, handy person, so I will consider most any recommendation that seems reasonable. Bring on the tips!
Thanks, Jules
Thanks, Jules
