- May 22, 2013
- 2,796
- Plaster
- Hayward Aqua Rite (T-15)
As far as how long to wait to test it's usually recommended to test every hour at first but it's a guide. The purpose of testing frequently is that at first the chlorine gets used up very quickly. As you test and add and test and add you'll start to see a pattern as to how much gets you up past the SLAM level and how fast it's dropping. They do recommend that until you pass the three tests that you do test a minimum of two times a day. Your test results and progress of killing off and cleaning up your pool will guide you in how often YOU need to test YOUR pool.
Your SLAM is successful when:
CC is 0.5 or lower;
You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
And the water is clear.
CC is 0.5 or lower;
