Type: In ground gunite Infinity Edge spa
Size: 9' x 8' 3"
Perimeter: 17' 4"
Surface Area: 74.25 Sq. Ft.
Volume: 1088 Gallons (Not counting surge tank)
Water Weight: 9,074 Lbs.
Initial Design Plans - all selection subject to change
Some posts I've read recommend staying with one brand of automation for compatibility reasons. The automation system should be able to control the spa, lighting, maintain PH and chemical balance, landscape lighting etc.
Inevitably, water will splash/spill onto my grass, hence I want to install a low chlorine system. I am considering running a mineral spa with metals and an ozone generator.
If you could start from scratch, what would be your ideal system?
Thank you for sharing your knowledge and insight.
Size: 9' x 8' 3"
Perimeter: 17' 4"
- Automation System - Hayward
- Filter - Pentair Cartridge Filter
- Heater - Raypac
- Pump - Jandy or Pentair
- Lights - Jandy
- Jets - Still looking
- Etc.
