- Jul 16, 2022
- 10
- Vinyl
- Liquid Chlorine
- Intex Krystal Clear
New to pools. I have setup a 1236 gallon AG bestway frame pool. It has a 330 gph filter pump but states a system flow of 280 gph. It has been managed willy nilly without the proper test kit for two weeks. The TF-100 hopefully arrives today. The water is a little cloudy. When I add standard bleach (7%) it clears up for a short period. The walls are not slimy, but I have been skimming and brushing regularly. I have vacuumed a couple times. Before I found TFP I added 2 oz of cal hypo, twice, two days apart. I have since purchased standard bleach and stabilizer but not used the stabilizer.
I was given a larger pool with a 1000 gph filter pump (RX100) and a Kyrstal Clear M#CS8110. I don't know how the previous owner kept his water or the condition of the SWCG. I do see a little calcuim build up inside it. How should I go about evaluating it?
The SWCG has a minimum flow rate of 700 gph. Would installing the larger pump and SWCG be a bad plan as it is over sized for the little pool? Should I be patient and wait until next year's bigger pool(14' x 48") to use the SWCG?
Once the TF-100 arrives, I can test the water, after which I can get started. Is there a recommended sequence for balancing? CYA first, then pH, then FC, then... or is order of operation not so critical? Also, I am assuming it needs to be SLAMed because of the cloudy water and lack of FC up until now. If so, should I initially keep the CYA lower to keep the required SLAM FC lower, or get the CYA to the 30-50 to protect the chlorine?
I will post test results as soon as I have them.
