Ok, so according to pool math, it says I'm going to need about 7lbs of stabilizer by weight (if I did that right). I noticed everything also says that increasing CYA will also decrease PH. Since my PH is so high, and I should have the pool cleaned out in the next day or two, should I hold off on adding the muriatic acid until a week or so after adding the stabilizer and then recheck everything?
