Hi All,
I am looking for some advice here.
I just got a new fiberglass pool installed with built in hot tub. The contractor turned on the systems for the first time on Friday, and honestly I was very disappointed with the results in the hot tub (the pool was perfectly fine).
Issue:
The jets have no pressure at all in the hot tub and no air bubbles were coming out either. I have 6 jets installed and there is a small pipe outside with air intake. The bubbles come if I use the blower side of the shop vac to push air into the pipes.
I have tried to put hands on 2 of the jets to cover them, and that does result in slightly better pressure on other jets and little bit of bubbles.
The contractor states that this is normal for inground hot tubs (which I don't believe) and stated that he clearly told me that I won't get the same effect of a hot tub sitting outside (which I don't recall at all).
Equipment:
I have pentair 2.5 hp variable speed that controls both hot tub and pool.
The pipes are 2.5 inch or 3 inch pipes (not quite sure) for both returns and drain / skimmer.
In the video of hot tub running, I have shut off the returns of the pool and only using hot tub returns. I have also turned on the pump at full rpm of 3450.
Here is the link for the video (Sorry not sure hot to upload video here)
The builder's solution is to put a bigger pump (5hp) and that should make it better but it might still not be the full effect.
Thanks for any help or suggestions.
Issue:
Equipment:
