Hello Guys,
After receiving 2 Fiberglass and 3 Gunite Pool quotes, we finally have a contract in place to get our pool / spa built. This was a bit of a hard decision for us as we were shown a design (pictures attached) that we absolutely loved by one of the initial PB's that we received a quote from but ultimately had to change the design for the reason that the L shaped pool wouldn't accommodate an automatic cover. After extensive consideration, we just felt that the combination of having younger kids (8 year old and a 6 year old) combined with the additional pool cleaning aspect necessitated an auto cover. Therefore, we had to modify the design a bit and decided to go with a rectangular based pool, which isn't quite as unique but still nice, to get that cover. We also decided to drop the stone faced raised beam on the backside of the pool when going to the rectangular design as we didn't think it looked quite as nice on a rectangular design. The wall just looks to imposing in our opinion when the design changes. The new PB has not done a 3D of the new pool design yet but promised that one would be generated soon and I'll post it when I get it. As for the new design, it'll essentially look like the sketch I drew up that is attached, let me know what you guys think!
Also, we are still very early in the process so can still change things around here and there, if you think we should or shouldn't do something don't hesitate to voice it as we are rookies in the pool space - 1st pool build for both my wife and I.
As for the specifics on the contract to this point:
Pool: 18'x39' Gunite Pool w/ 8' x 12' Tanning Ledge (702 sq.f)
Spa: 8'x8' elevated spa 18"
Depth: 3'-7'
Pool Formation and Rebar Installation: Pool forming and rebar, mesh installation #4 rebar 12" of center, exposed beam is to be double mesh
Plumbing Materials: Pipes 1.5"/2" schedule 40 solid PVC, 2-skimmers, 2-return outlets, 2-main drain, 8-spa jets, 6-Jandy/Pentair 3 way valves
Pool Shell Installation: Shotcrete/Gunite at max 4000 PSI. 11" beam, 7"-11" wall, and floor.
Pool Equipment:
Coping Stone: Silver Travertine
Pool Plaster: SGM Diamond Brite Steel Blue
Pool Deck: Silver Travertine French Pattern Finish Pool Deck and Patio
Installation: Exposed Beam and Spa Waterproofing and Veneering and steps (Chocolate Gray)
Auto Safety Cover: Under Mount Cover Star Pool Cover
Spa Hardtop Cover: 9x9 Demux Top Cover
Thanks!
Nabeel76
Depth: 3'-7'
Pool Equipment:
- Pentair Intelliflo VSF Variable Speed & Flow Pump 3HP 230V I 8-Speed Settings/Timer
- Pentair Clean & Clear Plus 420 Cartridge Filter
- Pentair Intellicenter I5PS Pool and Spa Control w/ SCG
- Pentair Intellilevel Auto Water Leveling System
- Pentair Globrite Color LED w/ 100' CORD 12V 23W (6 Lights)
- Pentair MasterTemp 400 Natural (Gas Pool Heater at 400K BTU)
Thanks!
Nabeel76
