YES! You did wonderful!
How does your water look?????
If you water is so clear that you can read heads/tails on a coin you can go to Maintain! Use FC/CYA chart to find your levels. You will need to keep a running chart of your FC levels with notes about the sun/clouds. This will help you know just how high you need your FC to have your minimum at the end of the day.
Cover-That is up to you. Make sure it is CLEAN. Did you clean it with bleach water??? I would just to be sure there are not yuckies on it.
Kim
Kim
