Sorry for the delay -- too much to do, so little time.
Friday, during the night it was filling up. There was quite a bit of cloudy material in the pool.
Saturday, pool filled up and looking great. They did a hot start on it where they put in 6 gallons of muriatic acid. They would normally use 8, but it was going to sit all day Saturday and Sunday. The idea is to fully disolve all the dust so it doesn't have to be filtered out. It worked quite well. There is a bit of a slippery dust/scum layer on the pool that had to be brushed off, which I assume was partially dissolved plaster. The acid did bring out the small grains of quartz and other material. They shimmer in the sunlight, although the surface isn't as soft/smooth as it was.
On Monday, they neutralized the acid, turned on the pump and put in 3 trichlor tablets. They put one in the skimmer basket (hmmm, I've seen places that said it would damage the plastic on it). No CYA added at this point, they wanted to let it finish curing. They put in sodium bicarbonate in the water with the sun shinning bright. The added particulates caused the glass (and glow-in-the dark) tiles to reflect, sending light shafts out of the pool.
Monday night, everything looked great. There has been a full moon that overwhelmed the the glow-in-the-dark tiles; however, the tiles are glass, so they reflect the moon glow, really causing them to stand out.
Tuesday morning, looking good. I started running my own chemistry, adding 10% pool bleach. pH was good, and I was letting the plaster pull it up before lowering it with acid. A friend had told me to get a solar cover, so I did Tuesday morning. By Tuesday afternoon, the water temp was 78 degrees. I took a quick dip (got to love Tucson).
Wednesday. My kids finally got their first dip in the pool. They loved it. Similar frolicking Thursday and Friday. The pool temperature was 84 degrees today with help of the solar cover.
Friday, I had my pool school. I was pretty disappointed with the lack of depth he went into. I would hate to have to take care of a pool with as little info as I got (I think he assumed I knew a lot). He brought over my aquabot Turbo t-jet. It works nicely; however, the main drain and skimmer did a decent job by themselves. He put in about 2 pounds of CYA, which I tested to be around 20 ppm this evening.
I will post pictures of the glow-in-the-dark tiles soon, they turned out excellent. I need to take pictures without the moon and calm weather. I ended up scattering 3 dozen tiles on the floor to look like stars and even put in the Orion constellation, and it looks pretty cool. What is really awesome is the pool light will recharge the tiles. Thus, you can run the light (which is a 70watt LED) for 10 minutes, turn it off and get the tiles at full glow -- so cool.
