- Oct 11, 2022
- 16
- Plaster
- Pentair Intellichlor IC-40
Hi everyone, as the title says, our pool was completed last month, and overall we're really happy with it. Unfortunately it's quite cold (even here in San Diego) currently, and with the current gas prices, it's prohibitively expensive to heat. We're looking in to solar thermal heating, and that should help us extend the usage a little more than only summer. We have used the spa a couple of times, because heating that is a manageable cost, and after having spent so much money having the pool built, it hurts to just not use it at all!
So the details of the pool are:
For the first month, the pool company did not add salt or enable the IntelliChem. They visited once / week to check pH and Chlorine, adding both Chlorine and Muriatic Acid during those visits. At some point during this first month, I turned on the IntelliChem just to get a read of pH and ORP in the ScreenLogic app. It noticed, as you might expect, that the ORP value jumped high when the pool company added liquid chlorine, and then slowly trended down over the next few days. By the time their visit on Friday hit, the ORP value was very low. The pH on the other hand drifted from 7.5 up to about 8.2 over that same time period.
Last Friday was the last 'free' visit from the pool company, and they added salt to the pool and switched on the IC40. They intentionally added less salt than they expected to need, so as not to over dose the pool. I've been monitoring the salt level reported in ScreenLogic from the IntelliChem since then, and have added the remaining two bags they left behind (10 total so far) because the salt cell reported the salt level so low that it wouldn't produce Chlorine.
At the same time during that visit, we also tested Alkalinity and Calcium Hardness, getting results of 70 and 150 respectively. Baking Soda was added at that time, and I've since tested the Alkalinity yesterday, getting a result of 110.
I've done some reading about LSI, and the IntelliChem and EasyTouch, as well as the ScreenLogic app have internal calculators to do this for you based on partial manual measurements. Most of my questions at this point are related to water quality parameters and testing.
Main Questions
I wonder then if a balance of 250 ppm Calcium would make more sense, yielding the following:
Additional Question
How important is a sacrificial anode in a salt water pool. Clark Synthesis, who makes the underwater speakers that I have, suggests that it's very important when using their speakers because the magnets in the speakers attract dissolved or small iron particles, which then rust in the water. The speakers themselves do not rust, but the suspended particles all collect in the same place, and can create unsightly stains as a result.
I spoke to our pool builder about this, and he had never heard of fitting a sacrificial anode to pool plumbing, except for the case where low voltage LED lights are used, and there isn't a bond wire from the light to the rest of the equipment. In this case it's not really a sacrificial anode, it's a water bond wire of some kind.
They said that they could fit whatever I wanted in to the plumbing, but for whatever reason we never got around to it and the project has completed. I've ordered a 2" T type zinc anode though, and plan to fit it just after the pump. I just wondered if this was really common practice or not.
Thanks in advance guys!
- 18' x 36' - 6' deep at the deep end, 3.5' deep at the shallow
- 7' x 7' spa, offset by 18" in height, and length, and about 6" in width
- 2 spillways from the spa to the pool
- Blue Surf Pebble Sheen + Abalone finish
- 2 x Clark Synthesis Diluvio underwater speakers
- EasyTouch 4, upgraded to EasyTouch 8 (thanks to posts on this site)
- IntelliChem with pH and ORP sensors
- Acid Tank with Dosing pump
- IC40 Salt Cell
- Mastertemp 400 heater
- IntelliFlow3 VSF pump
- 3 x IntelliBright 5G Color Changing Lights (2 in the pool, one in the spa)
Main Questions
- As mentioned above, we have an IntelliChem reporting pH and ORP values, and controlling Acid and Chlorine generation respectively based on these readings. Aside from periodic sanity checks, do I really need to measure pH and Chlorine with my test kits?
- What is ORP, and how is it related to Free Chlorine, Combined Chlorine etc?
- What is the difference between the Chlorine tests in K-2005 and K-2006; why is the K-2006 version preferred?
- I notice that temperature has a very big impact on LSI, and if so, what are the optimal Alkalinity and Calcium Hardness levels for a pool with spa in my region (San Diego)?
- 110 ppm Alkalinity
- 300 ppm Calcium
- Winter 55 temp (7.6 pH) = -0.22 LSI
- Summer 82 temp (7.4 pH) = -0.07 LSI
- Spa 100 temp (7.4 pH) = 0.11 LSI
Additional Question
