- Jul 31, 2021
- 172
- Plaster
- Pentair Intellichlor IC-40
Been helping a friend getting his new pool up and running.
Setup
Sand filter, pump STA-RITE SuperMax VS 1.5hp, heater aguacomfort act1100 heat pump 93kbtu, equipment 60 ft from pool, 1.5" flex PVC pipe 1 run for returns and 1 run for drain/skimmer, frog system (I know pool builder said swg would ruin his steel supports), steel vinyl pool half in ground 11k gallons.
He has to run pump at 2800/2900 RPM (3k max cont) to keep the heater going which needs 20 gpm min to run. I had him try bypassing filter no change. It seems like should not be at 90% max of a vs pump for normal operation before any increase in pressure due to filter build up wear and tear.
Does this seem right/normal? Looking at pump for this flow it's a 45-50 ft head for 20 gpm. My pool runs at 1000 RPM for same flow rate but better plumbing and uses 1/10th the power. I'm thinking his pb screwed up something. Very least seems like needs much larger pump but wondering if something else is wrong.
Thanks for input.
Dave
Setup
Thanks for input.
Dave
