We now have 3 estimates for relocating the electric lines and adding a sub panel. Bids are so different from each other in terms of the scope of work. Estimate #1: upgrade existing main service panel to make room for pool. Connect upgraded service to pool panel (80-100 amp) by equipment pad. Estimate #2: Leave house service alone. Add separate pool panel (100-120 amp) and have it connect directly to meter. Also add a separate main breaker switch for house service. Estimate #3: Leave house service alone. Switch out current meter for a "combo" meter that will include the sub panel (100-120 amp) for pool and main breaker switches for both house service and pool service. All of these estimates are in the same $$ ballpark so I don't get a feel for what is the best way to go. Estimates are all between $2500-$3200 for this part.
The trenching to relocate the lines pretty much doubles those numbers. Because we need to work around the gas line, the new trench will be long and a final number will only be given once the trenched lineal feet are known. (estimates for the trenching and laying the PVC are betw $3200-$3600). Also, we have to use materials directly from Florida Power & Light and pay a fee to FP&L ($500-$900 depending on size of job). Then, I need to add the cost of the permits which is another several hundred.
Any thoughts on the electrical panel proposals? The last 2 make the most sense to me in terms of leaving the house service alone and just adding the pool panel separately. Anything else I should be considering? Estimate #3 came from an electrical contractor recommended by PB. Estimate #2 EC was recommended by a neighbor. Estimate #1 recommended by a friend.
