Hi All - New to the forum, not to pools but def need some help/reassurance.
Back Story
Just Closed on a house and inherited a not so ideal situation with the pool.
Went to Leslie’s to buy a Taylor test kit and took along a sample with me for a free test (I know, I know).
CYA levels reported by Leslie’s at 140 ppm but FAC was in range for 140 CYA. Came home and drained about 40% to do a dilution and get CYA in the 80 range (still hot in Houston so was ok keeping it a bit higher). About 3/4 through the fill I walked out to see that the pool had started to turn green. Spidey senses went off telling me something wasn’t right so I tested myself and got the following
FAC - 10
PH -7.2
TA -100
CYA - 200 (had to use the dilution method to get a readable test)
After getting the real CYA reading it all
Made sense….
So I just finished another 40% dillution, tested CYA and am getting about 100 ppm. Went ahead And brought FAC up to slam levels. I really don’t want to do another dilution due to cost so, Plan is to ride this slam out, and hope CYA levels drop a bit in the next few months (pool gets full sun and it’s hot in Houston). If I need to dilute again in a few months I can - after my wife forgets about this water bill .
What do y’all think! Is the plan a good one? Should I be doing anything different?
Back Story
FAC - 10
PH -7.2
TA -100
Made sense….
