- Apr 13, 2023
- 4
- Plaster
- Jandy Aquapure 700
New plaster, Pebblesheen, filled end of July. Have been adding muriatic acid 2x/week to get PH down (PB says that will continue as plaster cures), which gets the PH down to 7.6 or so, but then it always climbs through the week. TA is also persistently high, and CH is consistently low. Do you recommend I get the CH up, and drive the TA down by lowering the PH to 7.0-7.2 and aerating? If yes, in what order should I do that? See my current readings below (Using the TFP Pool Math App, which is awesome btw):
FC: 7.5
PH: 8.0
TA: 120
CH: 225
CYA: 90
Salt: 3000
Temp: 86
CSI: 0.26
Thanks for any help/advice you all can provide.
Doug
FC: 7.5
PH: 8.0
TA: 120
CH: 225
CYA: 90
Salt: 3000
Temp: 86
CSI: 0.26
Doug
