I replaced the cell due to low salt level reading, However, new cell only reads 2000 and I have reset several times. what could be the issue
Green and clean t-9 cell purchased on ebay oct 21 it has no s/n worked fine until 4 days ago. New cell now reads 1600 vs 2000 and both check cell and salt lights are onWelcome to TFP.
Details please. What system? What cell did you have? What did you replace it with?
How did you reset?
clear cell to see cellsGreen and clean t-9 cell purchased on ebay oct 21 it has no s/n worked fine until 4 days ago. New cell now reads 1600 vs 2000 and both check cell and salt lights are on
can you recommend a new cell to purchase or do you think it is the chlorinatorCan you post a picture of the label and serial number of the cell you removed?
How many gallons in your pool?
i have the hayward goldline chlorinator with the software version of r 159. The new cell from amazon is a blue world BLW1T3H T3 cell my pool is 10K gallons
You are replacing a T-9 cell with a smaller T-3 cell.Green and clean t-9 cell purchased on ebay oct 21 it has no s/n worked fine until 4 days ago. New cell now reads 1600 vs 2000 and both check cell and salt lights are on
10kYou are replacing a T-9 cell with a smaller T-3 cell.
Your control panel is set for T-9 and needs to be reset for T-3. That is why the salt readings are incorrect.
We recommend a SWG be rated at 2X the pool volume. The T-9 is for 25,000 gallons and we think it should only be used in pools less than 15,000 gallons. The T-3 is 15,000 gallons and is appropriate for a pool less then around 8,000 gallons.
what does SWG stand for is it a make of cell? or salt watyer generator?You are replacing a T-9 cell with a smaller T-3 cell.
SWG = Salt Water Generatorwhat does SWG stand for is it a make of cell? or salt watyer generator?
This is a very important question that needs answering… A k-1766 Taylor salt test is the ONLY way to know a true salt content. Not pool store testing, guess strips, SWCG reporting, etc.Was it the K-1766?
just orderd a new gold works t9 cell from amazon to replace t3This is a very important question that needs answering… A k-1766 Taylor salt test is the ONLY way to know a true salt content. Not pool store testing, guess strips, SWCG reporting, etc.
