- Jun 8, 2021
- 26
- Vinyl
- Intex Krystal Clear
This is more just to start the diary of my adventures getting my pool cleaned out. To start I have read through the how to guides, and my TF-100 kit arrives today. So I can start giving some precise numbers and have a better idea of whats really going on.
But to tell the back story. It's a Bestway above ground 20'x52" pool. First year was great with no problems. I used chlorine tablets and 7-way test strips and kept everything in line.
However the first winter I didn't cover the pool fast enough and got some leaves and stuff in it over winter. However I was able to clean it out and get it going, probably mostly by luck, and with shock and algaecide. Still using chlorine tablets (you probably know where this is going). Kept it mostly in line all summer, but towards the end of the summer I started having trouble with algae. I had noticed my cya levels were getting high. So I started to read about how to fix that. Somewhere in my internet searching, I found this place. Loved the idea of keeping it simple and using readily available chemicals. I probably should have got a better hold in the pool last year, but didn't. Before I put the pool away it had turned green, and again I didn't cover it. At all this winter. (I know, super bad idea, especially as it's surrounded by trees, and then we had the worst winter in a long time).
So I started this year with a mess. Plus my cartridge filter had developed a leak over the winter. So with me being tired of buying filters I "upgraded" to a sand filter. I refound this site and read up again on the SLAM method. But before I started, knowing that my CYA levels were high, I drained most of the pool. Like down to 6" or less. And this was probably my first mistake, as I didn't get in there and really try to clean out all the leaves and debris. I mean I didn't have to last time.....
So I refilled the pool, checked out the pH levels, which were good, and started hitting it with chlorine. I also added about 1/2 the amount of CYA recommended for my pool size. As I don't want to get it too high right off the bat. But so far I've only used liquid bleach, and out of frustration 2-3 treatments of shock. But going forward I only intend to use liquid bleach unless recommended otherwise.
I've still been using test strips until my tf-100 test kit gets here. Hopefully today. But I've tried to keep the free chlorine levels at 10ppm+. But honestly can't say I've been the best at it, and definitely haven't ever checked it every hour. I vacuum or brush it every day. I even bought one of those leaf eater things. I just recently realized I should be using "waste" when vacuuming. I was having to backwash my filter every 1/4 or so of the pool. I had the return hooked up to a hose above the water level, and when I saw it start to spit out dirty water, I would quickly stop and backwash it. But the last couple of times have used waste. It works well with the leaf eater adding water. I have also added the treatment dose of some algaecide probably 3-4 times. Just trying to gain some kind of ground. I've ran the leaf eater 2-3 times now. I keep thinking I've got to have gotten most of it, but as I can't see the bottom I really don't know. But then the next time I vacuum or leaf eat, I get more. It has lessened. But I really don't know how much is still down there.
Anyway I've been doing that for a week or two and last week decided I needed more help. So came back here, reread through everything and ordered the TF-100 kit. I've still been trying to keep the chlorine up above 10 ppm. Other than when we lost electricity, the pump runs 24/7. It's a Bestway 2000 gph sand filter. I bought the sand at Leslie Pools. I've also bought some DE aid as I've read about adding some of it to help the filter get the algae. I haven't added any yet.
Pool is still greenish. I think it may be getting a little lighter, but I can't see anywhere near the bottom yet.
So after all of that, let me have it. Any ideas, suggestions, opinions? I'm all ears. And I'll start taking measurements as often as I can. The problem there is I work 2 jobs, and monday is my closest to a day off. I'm normally free from 10 am til around 6. Maybe later if my boys don't have a baseball game. So that will be the next time I can do the part about checking the Chlorine levels every hour. But at least according to the strips, the FC has not been getting below 3-5 ppm at any point of tested. And the only times it's gotten that low is either the time the electricity when out (fluke thing I don't expect to happen again) or the one time I was out of town and didn't get to check it for 12 hours.
Fwiw I normally check it aroud 4 am on my way to work. Around 9 am after the first job. Around 2pm on my lunch break, and sometime between 7-9pm depending on baseball games.
Thanks in advance.
Thanks in advance.
