I need to replace the valve with the broken handle with a new diverter valve, The valve the builder put on is Crud and gave me issues when they closed the pool recently. Basically the valve didnt close all the way leading to the air lock leaking and then the handle broke off.
Im going to replace it with a hayward 2" 2 way diverter valve (all my pool valves are hayward so wold like to keep it the same), I just want to confirm this is the right one - Hayward PSV2S2DGR 2-Port PSV Diverter Valve
The pipe is a 2" pvc pipe.
The other thing I want to do is put a union on the pipe for the spa pump, What is the best way to do this?
Should I just add a 2" slip union after the pump before the valve or should I add a threaded slip union at the pump inlet like my pool pump has (circled in red).
I don't care which is easier, I want it done the proper (best) way.
