I am so glad I found a place to post this and hope I get a quick answer.
I have an intex pool and I filled it with well water. (Around 1780 gallons)
I watched videos over and over and thought I had a good idea of how to make it right. I was wrong.
First off I didn’t know that well water would be more of a challenge.
When I first tested it, everything was 0. I was under the impression I needed to get TA & PH balanced before adding chlorine. One of the reports told me to put in 68 pounds of Borax (i am using bbb method). (Maybe it read my 1780 gallons as 17k. I dont know. But, only had 4 pounds so I put 4 pounds of borax in. 2 pounds of Baking soda in.
I let the skimmer float with a couple tablets in but then took them out when i saw the filter turning brown.
I have put two 3 oz of ph decreaser because did not have MA.
Now I’m reading about iron. I have changed 3 brown filters in 2 days not used any chlorine and TA and PH still hi.
I read on here somewhere I should add chlorine. But I have also read don’t add chlorine till TA & Ph balanced.
I had some iron out and put a tiny bit in. The water is clear. Its just the filter getting brown.
Would someone please tell me what to do. Getting bad info on a test got me putting the wrong amout of b & b in to begin with. I am testing with strips and a test kit and still get different answers.
I need a person to help. I am new to all this chemistry stuff. So thank you for any help. (I am in NC).
