I've been a Pentair guy for the last 10 years or so. However, I've had to replace two Pentair Sand Dollar filters in the last 3 years due to pinhole leaks that developed at the seam. Because Pentair seems to have only a 60-90 warranty if you install it yourself, neither was covered under warranty. Needless to say, I'm considering Hayward or other vendors - if for no other reason than warranty. I'm also considering replacing replacing my single speed 1.5 HP pump with a two or variable speed pump to save on energy. I've heard good things about variable speed, but also heard they can be problematic and that two speed is the way to go for the money.
What is the best manufacturer for quality products and warranty? What sand filter should I consider? Should I go with Hayward, another company, or stick with Pentair again? Should I go with two speed or variable speed pump? I would appreciate any advice!
