You’re right at minimum fc for your cya so I would bump that up to high target with liquid chlorine. FC/CYA Levels
Everything else looks to be within recommended ranges What Are My Ideal Pool Levels?
How does the pool look?
It looks like you're using the 25 ml sample size testing option. For the FC and CH tests, using the 10 mL sample will help conserve reagents while still providing sufficient accuracy.
