- Feb 17, 2022
- 391
- Plaster
- Pentair Intellichlor IC-40
I was able to find a new drive motor for it online after some searching for $120.00. that along with everything else should make it pretty much new. Hopefully i can get a bit more life out of it.Sadly the motors (drive and impeller) cost next to nothing. I’d be surprised if they cost more than $20-$30 a piece. Even with the completed mounting adapter on them, Maytronics could sell them for around $100 and make a nice a profit on spares. But they don’t and they only want the end user to either buy an entirely new motor assembly for $500 or a completely new robot for $1000. It’s ridiculous but that’s their business model. It’s why I went back to using a suction cleaner, I’m not playing their sucker’s game.
Good luck resurrecting your robot. I hope you can get more life out of it.
Nope, discountpoolmart.com
They had one in stock and shipped it 2 day air.
Mind you i have the Dolphin CC. No plus nothing fancy just the cheapest robot you can get. Could be why it was available.
The motor assembly I bought came with the transmission and motor as one piece ready to drop in and go. It may be a left over. If so, i may buy one more considering this whole adventure has been only about a third of the cost of replacing it.I believe all those motors are basically the same. The ones they use to drive the Nautilus are also the ones they drive the S series and other bots with. The trick is not damaging the transmission assembly that’s bolted on to the motor as that is how they achieve the torque needed to run the treads and the brushes. Those spares used to be readily available but I was told Maytronics stopped shipping them to retail stores because they didn’t want the motor assemblies being repaired, just replaced. I assume there’s probably a small stock of them floating around out on the Interwebz. There’s also a seller on eBay out in Israel that would ship those motors to customers in the US. Israel is where the motor assemblies are built and so the parts are readily available there.
I haven't touched that one. I may, i am of a mund that if it isn't brone, don't fux it.Did you rebuild the impeller motor? New bearing are like $15 a piece and the carbon brushes cost very little. You can get a pack of them for like $9. It’s worth rebuilding the impeller motor as the carbon dust generated in the sealed motor housing really destroys them. After I rebuilt my impeller motor it spun like it was brand new.
Chinese engineering.It’s fantastically stupid that Maytronics designs these things with mechnically commutated carbon brush motors but that’s what they do. No engineeer in their right mind would ever use carbon brushes in a sealed compartment like that. It’s moronic but probably willed that way by the higher ups to save money and create “planned obsolescence”![]()
I would bet it is another example where the engineers don’t own pools or use the equipment they design.
Ok curiosity got the best of me. The brushes look ok but I'm in there so... Any idea what size I need? Bearings are smooth and rust free. Ill repack them with a good marine grease.
