Happy New Year Everyone.
Was vacuuming out leaves (had a bunch) from the bottom of the pool, happens every autumn so the procedure I follow is simple, vacuum until the pump basket gets full, power down, empty and resume. Eventually I get it all out and all is well.
This time though when I saw the suction stop and went to clean out the pump basket... it was clear but still no suction. I took the pump basket out and sure enough found a clog of leaves stuck in the pipe end, pulled them all out, cleared any clogs in the vacuum hose, back washed... still no suction. Pump working just fine, btw.
I opened up the filter itself and it's full of water. Took the grids out and turned to backwash with the filter top off and while running the pump I see plenty of flow coming into the filter, but still no suction.
Seems to me there is a clog from the skimmer to the pump. I don't have a plumbing snake, all I have is an electrical fish tape which is long enough to get to the pump basket but not flexible enough to get past the right angles of the pipes.
Should I try shoving my garden hose into the skimmer pipe and try to force water through with the pump basket lid open?
Thought I'd come here before trying anything off the top of my head.
What do you all think?
Jim
Jim
