jcowart
Well you can work with 80. It will just be a higher target and you will have to stay on top of it. Plug 80 into pool math and see what it shows for min FC. That would be your lower limit with a daily target about 2-3 ppm above that. Go on and start the slam process. It should not take long unless you have a lot of yellow. Maintain it like that until you can get some more drains in. Just know, it might seem like a lot of bleach to get from 0 to slam with cya at 80. Once your there it should not take as much to keep it at slam.
Sent from my VS870 4G using Tapatalk
