Haven't ran the heater all summer. Unsure of the age but everything inside is very clean and all the rubber tubing and other components still look brand new. After trying it last week, it fired right up, and then after about 3 minutes it turned off and the service heater light came. I took the cover off and the SFS light is on. No other codes on the screen. I rebooted it and started it again watching the SFS temp and it quickly shot up to 480. The manual says to check the thermal regulator first. I pulled it and it looked somewhat corroded, it would not open under my kitchen sink hot water so purchased a new one. After installing the new thermal regulator I started the heater and it ran for about 10 minutes and then got the SFS code again.
I checked the resistance of the sensor while installed and got 3.138. Inside the house is 3.3-3.5. Played with it in cold water and hot water and am pretty convinced it works but please advise. Hot tap water decreases it to 1.1-1.2 and cold water from the refrigerator brings it up to 4 and then my meter shows the overload symbol (I believe). Tracks similar with this post. I have continuity between the wires at the sensor and the control board.
Not sure what to do next. The diagnostic guide from the manual has the next step from continuity - does it show E05 or E06 (no) and then from there, basic model has the next step as replace control board. Since I have the 5 button I'm not sure if I want to immediately upgrade to the new control board and screen if that isn't going to solve my problem.
In this thread, it is suggested to try running the heater with the thermal regulator removed and monitor stack temperatures. I have not done this but will do it and observe what happens as soon as I can. Also, Mknauss mentions that it is possible the thermal regulator is not in the hole it is supposed to sit in. I tried 3 or 4 times to get it in there properly, I could hear the ridge of it clicking on the plastic and I think falling into the hole. But will try again several more times after running the heater with it removed. It is certainly possible the new one is not installed properly.
Another thing I did is I ran the heater with the SFS sensor disconnected to see if it would throw a code. Surprisingly, it did not. It started up and worked for a few minutes before I decided to turn it off. During this time the stack temperature on my display read 40. I'm not sure if this is indicative of a failed control board. I don't know what it is supposed to read when you disconnect the sensor. Additionally, during all of these tests, I don't find the surface of the burner/furnace area and the exhaust or grate/piping to be all that hot. I can touch them with my hand for a few seconds while the heater is running and when it turns off for high SFS temps. Next is an IR thermometer to confirm but still really not sure.
Tried to do as much research before making a post as I could but not sure where to go other than a new control board according to the manual. Thanks.
