I have a few extra omron relays for my compool et upgrade setup. I use a Jacuzzi JSCS-40 on AUX7 so I can schedule its startup and shutdown (usually 1/2 hour after the pump is scheduled to start and before shutdown). Im thinking of introducing a flow switch on the low voltage side, basically cutting LV wire and attaching it to the flow switch to ensure there's flow before starting up the salt-cell.
My pump equipment is up hill, and Im getting to the point where I feel comfortable leaving it running unattended for a few days, but dont want to run into situations where I loose prime for any number of reasons and have the salt-cell continuous to produce chlorine gas despite claims of having its own pressure sensor.
Anyone see any issues with this? I believe the flow switch works by making contact and closing the circuit, so I think I should be able to splice the contact low voltage side and that would give me the security Id like to have. Any concerns here?
