There are two things I recommend you do when you receive your TF-100 kit.
1. Test the CYA with half of the sample water from the pool and the other half tap water. Mix this with the reagent and then the CYA level will be double the reading. This gives you a more accurate result when the CYA is above 100. With this information we can tell you how much water will need to be drained.
2. Raise the FC level to a minimum 10 ppm with liquid a couple of hours before it is dark. Take a FC reading when it is dark and take another one in the morning before the sun is up. This is the OCLT and it will confirm what most of us suspect is that you have organics in the water and you will need to SLAM the pool.
