zea3 said:
Is the cover on your pump basket made of clear plastic? I can tell it's really dirty but I can't tell if it is supposed to be clear.
It is very dirty (mostly from age) but it isn't clear. Heres a pic inside while it's dry though
Well the adventure continued today
! I attempted to make a gasket from auto gasket material and it just didn't work. So I wen't to Delta Rubber and they cut me a circle that ended up working quite well! They also said to not put silicone around it like the previous one had to make a better seal.
Old gasket and new piece of rubber before I cut bolt holes:
After I got the motor attached again I turned on the filter and still didn't get any pressure, but instead noticed another air leak coming from the large hose in the ground that connects to the booster pump motor. I replaced this large hose with a water heater hose.
Sorry for the bad pic, but here is the 3/4" broken hose I noticed:
I replaced the small 1/4" hose between the two taps but it ended up breaking off at one of the nipples. On a whim I decided to switch on the filter while I plugged the broken nipple and end of the hose with my finger. Lo and behold heard water flowing and pressure building! I held on for a while and saw that everything began to function like normal. I finally knew all I had to do was deal with these two holes in the taps.
Based on JasonLions knowledge and many failed attempts to rig up another tubing method between the holes I decided to use fiberglass pipe repair kits on the two holes. Hopefully this will last while I live in this house, if not I will end up having to replace the entire PVC line! Anyone used these before and do you think they will hold?
So assuming nothing else breaks while the fiberglass is drying I have one last problem to deal with: around 10-12lbs of DE on the bottom of my perfectly clear (and stable!) pool floor. Should I just brush the pool and let it filter out or vacuum it up? Either way I know I'm going to have to do some backwashing or the filter will have nearly double the amount of DE!
Thanks for hanging in there with me, I felt like giving up for a minute!
