i have a 24' round pool and the liner has 2 seems on the bottom. well the center section has patchy discoloration where as the two edges are not. does anyone know why this might be?
PoolGuyNJ said:From: Scott
the only chlorine that gets put into the pool is from the shock pack once a week.PoolGuyNJ said:1) Cal-Hypo or dichlor powdered chlorine not pre-diluted well in water before addition can leave powder sitting on the liner.
unless the pool was sitting on the shelf for over a year + then no. purchased pool in april and set up in mayPoolGuyNJ said:2) Old liner
do not use chlorine products (see #1)PoolGuyNJ said:3) Cheap Tabs in floater not moving creates concentrated chlorine settling to the bottom and tabs are disolving quickly.
could not tell you here but its a 25 gauge liner (boulder bay print liner) purchased from rec warehouse in hampton roads VAPoolGuyNJ said:4) Cheap liner.
frustratedpoolmom said:.... then what's in the shock pack?
i finally got pics of the shock that we use and here it is... other than algeacide (that was last used in june) the only chemicals that i have used has been the shock.pool shockdmanb2b said:
