When I removed my top rail to install a light, I only had to loosen one side of the rail to provide just enough clearance to route the cord under it. My rail also had an area that was notched out so it continues to sit flush with the liner, you may want to look for a similar notch or area to run your wire. Mine was near a corner post, then I ran it down the side of the corner post. Hope this helps.
