- Jul 10, 2022
- 22
- Vinyl
- Intex Krystal Clear
The hoses are 1.5" with the threaded cuff and the pump side has the adapter with threads on both sides. Because the Teflon tape wasn't preventing leaks I removed that and started over.
I added liquid Teflon Tape to the threads and screwed the hoses on. They still leaked. I used the silicone caulk. I didn't give it time to cure so I'll check those connections later today but they each had smaller leaks yesterday after I applied everything.
The drain plug from the filter is also leaking.
I applied both to the drain plug. I wasn't able to apply it to a dry surface because even though I plugged up the pool and drained the hoses, there is quite a bit of water leaking through the drain plug. I replaced the drain plug once already and it just seemed like sand had somehow gotten between the plug and wall I'm assuming because nothing was damaged. I had both of them as tight as possible and they seemed to be fine for about 2 days before the new drain plug started leaking.
I'd love some ideas. It would be wonderful to actually get into and relax in my pool.
