Hello everyone.
So I'm planning on having a warranty request put in (we're about a week away from being out of warranty with all our pentair equipment).
I noticed this morning that there was a ton of fresh water all around the pump pad and when I look closer, I see there's an active leak from underneath the black screw ring thing (see pic, dont know what it's called). Over the past several months
I noticed a bit of mineral buildup of some sort around that pump compared to our other pump that gets used less...didnt think anything of it as I figured we clean out that filter way more than the other so more water gets splashed out. But now I think there's been some sort of very slow leak maybe?
At any rate, I would assume I'd see a change in the filter pressure but everything seems to be working fine, pool is keeping clean as usual, filter pressure remains the same. Should I be seeing a drop in pressure if there's an active leak at that juncture?
I tried tightening that black piece but it's on pretty tight. Maybe an O-ring issue?
